Hi, I need help on choosing case for my M-Atx build. I'm looking for a compact, simple, has front and back fan support, has PSU cover, and all black case with tight budget and found that the Thermaltake Versa H18 suits my budget and my criteria as well. But, is there anyone in here who had bad experience with this case?
And if you have a suggestion of other case that suits my criteria, and within the same price range with Thermaltake Versa H18, I'd love to hear it.
Thank you.
https://linustechtips.com/topic/976508-thermaltake-versa-h18/
Thank you.
I'm about to use it this weekend so I'll let you know if I find anything that offends.
I can tell you I flip flopped a lot between this, the Q300L and the Fractal Design Focus G Mini just to give you an idea of some of the cases that are worth your dollar.
https://linustechtips.com/topic/976508-thermaltake-versa-h18/#findComment-11796066
im gonna try to get the q300l soon, but i have the focus g mini right now. i will tell you tho, the focus g mini will not hold the test of time, cable management is virtually impossible, and the top of the case sags after having fans on it for 3 months. complete crap if you ask me.
https://linustechtips.com/topic/976508-thermaltake-versa-h18/#findComment-11796071
