Over a year ago, I bought a premade PC on sale for $450. It was a cybertron with an i5-7400 and gtx 1050, so the small case really did not affect it as much.
I have done some upgrades to it thanks to a better job. It now has an i7-8700 and, as of today I now have a 1080.
After I installed the 1080, my CPU went from 68c max to 87c under max load. The 1080 also has the slight issue of touching the plastic window, so I had to remove my front panel and angle it to at least try to keep dust out.
I have been looking around but I just cant find what I am looking for. I really want a case that lays on its side because I am a very, jumpy? person, not sure how to put it, but I shake my desk a lot when I do stuff and I have a fear of knocking over my pc.
My motherboard is an ASRock H310M-DGS, so its Micro ATX if that helps with finding one.
I have some images to show just how big the 1080 is compared to my case.
EDIT: also one with better cable management than this case... 1/4 inch is not enough space in the back for cables and it just kills me on the inside every time I have to remove the back panel.
IMG_20180925_235732_hdr.jpg.6d61b250ea87a32adcb52d3a7c5628aa.jpgIMG_20180925_235957_hdr.jpg.359718082d296cd64bcd6afbd61df3b0.jpg
https://linustechtips.com/topic/976194-need-help-finding-case/
14 minutes ago, ItsTheDuckAgain said:
Would one of those have enough room for the 1080 with out it touching the side wall?
EDIT: never mind, the link finally worked for me, internet is derping. How the hell did i miss these cases when i was looking?
https://linustechtips.com/topic/976194-need-help-finding-case/#findComment-11792226
  Reveal hidden contents
Must it be a cube?
I've been building pc for a part-time job lately (about 1month), and been doing alot of builds in the fractal design meshify C mini a lot.
It's classy, high air flow, and has very good cable management.
If you need the case for  custom water cooling go for the h400
The mini edition is meant for matx/mini itx,
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
https://linustechtips.com/topic/976194-need-help-finding-case/#findComment-11792321
16 minutes ago, Galion said:
Must it be a cube?
I could care less about the shape of it as long as it wont tip off my desk when It moves.
I am mainly looking for air cooling because i would forget to change the liquid in the system.
https://linustechtips.com/topic/976194-need-help-finding-case/#findComment-11792347
I see I guess the cube form dose give you more stability the air 240 will do nicely but if you can put it on the ground or on a stable surface the meshify c mini will the best choice
https://linustechtips.com/topic/976194-need-help-finding-case/#findComment-11792358
Thermaltake Core V21
https://www.newegg.com/Product/Product.aspx?Item=N82E16811133274
https://linustechtips.com/topic/976194-need-help-finding-case/#findComment-11808614
