Note 4 Issue when Factory Resetting
I decided to factory reset my phone, and it seems that after doing some stuff, it's now stuck on a blank screen and notification light is a solid red. Is this normal, or is this a problem? Its been about an hour and fifteen minutes now, and nothing has happeend..
https://linustechtips.com/topic/974202-note-4-issue-when-factory-resetting/
Note 4, hmm, that's a 5 year old phone. If you don't have any experience fixing it, go to a repair shop. It doesn't have to be Samsung or any Samsung certified technician since the warranty is most likely gone anyways. Best advice I can give you.
Other than that, time to upgrade?
-Kevin-
An FDR should be done in a matter of minuets, not an hour. There is something wrong. My guess is its time for an upgrade.
  • 3 weeks later...
I had the warranty through AT&T, and they ended up giving me a Note 8 for $100.
