So the rear fan in Apollo (hint hint) has been really loud. So, I took the grill out, and now the fan is near silent. Have a look!
This is what it looks like (those cuts are so clean and SEXY!!).
Only used a pair of wire cutters. The bandaid was needed since I cut myself on the heatsink of the processor taking it out.
What do you think, for my first real case mod?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/97419-my-first-little-case-mod/
Its beautiful *Wipes teary eye
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303013
Could be a little cleaner, but good attempt for your first mod.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303014
But for only using wire cutters...
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303032
Looks like a drill was used, was it?
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303058
Nope. Cheap wire cutters and my hand (the second pic).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303064
Nice!
That's nice for a pair of wire cutters.
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303069
Nice! Ya removing the restriction will make it much quieter because they sound waves won't hit it
It was TERRIBLE. There was a constant 40 decibel or so woosh. I might find my fan guard though so the cats don't cut themselves when it goes back on the floor (and possibly clean the cuts up more).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303074
ya, a fan guard is all you need, not what case manufacturers put which is like a 1:1 air to metal.
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303107
over 2000 post and you picked the  General Discussion
not bad for the tools at hand now just get a file and spend a few hours and good to go lol
Yeah noticed that right after I posted it xD My hand met my face quite rapidly.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303122
no I/O shield? :3
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303510
no I/O shield? :3
It was out of an old Gateway, which didn't have one. The case also doesn't have any PCI slot covers, and you can't even put anything in the bottom slot (cheap case).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303543
May I recommend using a hammer next time? Could be more fun... Possibly...
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303710
Hammer (time) what?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1303757
Aaaaaaandd... Apollo is giving me the large electric middle finger while I try to make a build log. Might be making my old Dell the music machine after all. :(
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1304179
Hahahaha, I don't know why this made me laugh so much, it looks like you tried to cut it out using a drill, but I suppose if it actually works then it's a good job.
Build 1: 4770k (H100i) | 2 x MSI 280X Gaming 3G | Asus ROG Maximus VI Hero | Corsair RM850 | 16GB Corsiar Vengeance 1600MHz | Corsair Obsidian 750D |
Build 2: 3770k (Titan Fenrir Evo) | Powercool 3GB HD7970 Asus Sabertooth Z77 | Corsair TX750 | 16GB Kingston HyperX Genesis 2133MHz Inwin Fanqua |
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1304431
I would never think of something this ghetto, GJ man
RIG-Processor: Intel core i7 3770k @4.4GHz,Mobo: MSI Z77-G43,GPU:Gigabyte GTX 770, RAM:16 GB G-skill sniper f3,SSD: Corsair Force f3 240gb,HDD: Seagate baracuda 1TB,Cooler:CM Hyper 212 evo, Case: Sharkoon T28 Blue
Peripherals- Monitor: Samsung S24B300, Keyboard: Razer Blackwidow, Mouse: Razer Abyssus, Headphones: Razer Megalodon, Mousepad: Razer Goliathus Alpha, Webcam: Logitech C270,Pad:Logitech F710, Sp: Philips generic ones
#KILLEDMYWIFE #MAKEBOMBS
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1304448
Did you even take the fan out to do it ?
Loving your work sir.
Nope.
And thanks. I have a fan. :D
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/97419-my-first-little-case-mod/#findComment-1325627
