https://support.rm.com/technicalarticle.asp?cref=tec1628410 Check that website it has a lot of good info if I had to guess somthing is up with one of your usb devices or a usb port.
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/973342-help/#findComment-11766519
Either something in one of your USB ports is shorting it out, or the port itself is shorting out. Try unplugging all USB devices and booting, then if it is successful, plug each device back in one-by-one until the issue comes back. That last device will be the issue. If the system still refuses to boot with no USB devices, it may be an issue with your motherboard.
https://linustechtips.com/topic/973342-help/#findComment-11766525
you have an USB device plugged in thats failed, or if you dont have any plugged in one of your ports has shorted somehow
Builds:
https://linustechtips.com/topic/973342-help/#findComment-11766604
Yeah, like everyone else has said: either there's something in a USB port using too much power (try unplugging everything), or a port is shorted (maybe take a pair of  tweezers and see if there's something shorting.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/973342-help/#findComment-11766660
