Cooling for new build
Go to solution Solved by PeterPanzer,
Thanks a lot for all of the feedback guys, you cleared the doubts I had regarding the CPU cooler.
Basically, since I am not going to overclock stick to air cooling and no need to go too high in price for the air cooler.
I will take into account the suggestions you guys made :)
Once again thank you all!!
Hi everyone,
I am in the process of upgrading a few components of my PC, one of them being the CPU and Cooler.
The CPU I choose is the i5-8600 and right now I am not sure if I should go with air cooling or liquid cooling...
The options I considered for both cases where:
  • Corsair Hydro Series H80i v2
  • Noctua NH-U14S
I don't plan on overclocking the CPU.
What do you guys think? Should I go with water cooling or stick to air? Are the options I choose good or do you recommend something else?
Thanks
edit: its the i5-8600 not the i5-8600k
https://linustechtips.com/topic/972868-cooling-for-new-build/
6 minutes ago, PeterPanzer said:
Hi everyone,
The CPU I choose is the i5-8600K and right now I am not sure if I should go with air cooling or liquid cooling...
  • Noctua NH-U14S
Thanks
Why are you buying a k sku cpu is you aren't overclocking. Sounds like you should just get the 8700 (non-k)
edit: the 8700 comes with a cooler 2
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761744
Just now, PeterPanzer said:
Ahh sorry it is the non-k i5, my mistake!
Yeah. That's a good CPU. Get it. But you don't need an aftermarket cooler. The stock one is fine
I know someone who has a 7700 with stock cooler and they are fine.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761751
another simple questions to answer yourself if you have to choose high end premium "accessories" for a mid range CPU
do you like the look of the cooler? thats all
any 9cm fan sized with 2-4 heatpipes unbranded coolers will serve this i5 great
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761759
If you REALLY want an after market cooler, get something like a hyper T2 or hyper 212. There are plenty of serviceable air coolers out there under $30. No reason to spend more.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761804
6 core vs 4c/8t
Although fine too, that justification is incorrect.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761809
Yeah both of those coolers are good.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761818
It's loud.
OP: get a Cryorig m9i or h7. Both are excellent coolers and in the case of the h7, you can reduce the fan speed to very low for a quiet build.
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761832
2 minutes ago, Firewrath9 said:
It's loud.
Not if you don't overclock it's not.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11761846
I don't want to go with the stock cooler, so its aftermarket for me.
If I understand correctly water cooling is overkill since I am not going to overclock, so you would recommend something along the lines of the Noctua I suggested above?
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11762042
since you're not overclocking, don't bother with the 8600k and get a locked i7 and B360 board instead, an M9i, aidos or hyper 212 will do, get whichever is cheaper.
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11762134
https://linustechtips.com/topic/972868-cooling-for-new-build/#findComment-11762715
