Hey guys I'm trying to build a mid level gaming pc, that i can also use to multi-task. Any tips or suggestions are welcomed and encouraged
PCPartPicker part list:
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler
Motherboard: MSI - X470 GAMING PLUS ATX AM4 Motherboard
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Storage: Kingston - A400 120GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI - GeForce GTX 1060 6GB 6GB GT OCV1 Video Card
Case: Thermaltake - Versa N21 ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply
https://linustechtips.com/topic/972341-help/
@Don Dre Increase the size of your SSD to atleast 500GB.
120GB Wont cut it for long, 240GB is gonna struggle with updates getting installed and so on so i say get a 500GB.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/972341-help/#findComment-11756824
I want to take a crack at this. One question, though: what is the maximum budget?
https://linustechtips.com/topic/972341-help/#findComment-11756851
Only two things I would recommend considering.
  1. Get a 250GB SSD instead. 120GB is on the low side of things once you get the OS and all your programs installed. I'd recommend at least 250GB for the SSD. Check out the WD Blue 250GB SSD and the Crucial MX500 250GB SSD. They come in both 2.5" SATA SSDs as well as M.2. If it's within the budget then the 500GB would be an even better choice, and would allow you to install a few of your favourite games on to the SSD to improve loading times.
  2. You don't need a 750W PSU. A good quality 450W or 550W will be a much better choice for that system, and you will save some money (maybe even save enough to upgrade to a higher capacity SSD!). Depending on what is available in your location, some good units to consider would be the Bitfenix Whisper M 450W, Bitfenix Formula Gold 450W, Seasonic Focus Plus Gold 550W, Corsair RM550x, or Corsair TX550M.
https://linustechtips.com/topic/972341-help/#findComment-11756852
14 minutes ago, W-L said:
-Moved to New Builds and Planning-
My apologies
I plan on picking up the parts one at a time so I'd like to stay reasonable but upgrading isnt really a problem
https://linustechtips.com/topic/972341-help/#findComment-11756865
Thanks!
https://linustechtips.com/topic/972341-help/#findComment-11756873
The Versa N21 is pretty dated in terms of its aesthetics and design. You can get much nicer cases for under $55.
Have a look at some of these and see what you think. Obviously it's a personal and aesthetics choice, but you should be able to get something a bit more modern than the Thermaltake N21 if you want to.
https://pcpartpicker.com/product/rnGxFT/cooler-master-masterbox-q300l-microatx-mini-tower-case-mcb-q300l-kann-s00
https://pcpartpicker.com/product/YhzZxr/fractal-design-focus-g-white-atx-mid-tower-case-fd-ca-focus-wt-w
https://pcpartpicker.com/product/FCs8TW/phanteks-eclipse-p300-tempered-glass-atx-mid-tower-case-ph-ec300ptgbk
https://linustechtips.com/topic/972341-help/#findComment-11756917
I like the Fractal Design.
Internet Speed.....
https://linustechtips.com/topic/972341-help/#findComment-11756924
Build something like this.....
Motherboard:ASRock - B450M PRO4 Micro ATX AM4 Motherboard
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory
Storage: ADATA - Ultimate SU650 240GB 2.5" Solid State Drive
Video Card: MSI - Radeon RX 580 8GB ARMOR OC Video Card
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply
https://linustechtips.com/topic/972341-help/#findComment-11757029
What a horrid case the masterbox is.
Internet Speed.....
https://linustechtips.com/topic/972341-help/#findComment-11757035
Looks horrific.
Internet Speed.....
https://linustechtips.com/topic/972341-help/#findComment-11757056
