How does water cooling works?
Go to solution Solved by Zagna,
There is a water block which touches the CPU, a metal block with fins through which the water flows and transfer heat away from the CPU.
This water is circulated with a pump through a radiator which is cooled with fans. So ambient air flows through the fins of the radiator and this cooled water is warmed by the CPU block. And then cooled in the radiator. And so on...
Watch this
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
