Searching for 120$ case with tempered glass.
Solved by TVwazhere,
1 minute ago, prodolphinplayer said:So, Meshify C TG would be the best?
Meshify C is very good, it's hard to go wrong with it. The only limitation is if you decided to upgrade your PC in the future and you want to use a liquid cooler mounted to the front of the case. In that instance, the Phanteks Enthoo Pro M TG would be a better choice. Otherwise, it's hard to point to a beyltter case if you already like the Meshify C as it is.
