so im thinking about painting my MX Master and i was basically wndering what color i should go with. any thoughts?
i like orange for the LTT color matching
but am open to other ideas
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
https://linustechtips.com/topic/968370-logitech-mx-master-best-color/
Personally I would go for lime green. As you can see from my profile, and username I'm a bit to familiar with the color.... :)
Although as a MX Master user, how are you doing this?
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
Image result for mx master white
what do you mean how? it takes apart pretty easly and then just sand, degrease and paint
55 minutes ago, Onboard87 said:
do you have any led or lights on your rig?
yes but all rgb and very variable so nothing to really use as orientation
EDIT: maybe chrome as a theme but thats really hard to paint and i ont think will look that good on the mouse
what about doing the three main colors than on the mouse so it always matches
if at first you don't break it you must have followed the directions
56 minutes ago, Enderman said:
just plain white? idk i think it needs some contrast and also has been done before and doesnt look that good imo
The more you know. Thanks, I'll look into this
