PSU calculators help.
5 minutes ago, Dizz_Man said:Well, I don't really fancy going over $150 AUD for a 550W PSU. Where I'm looking almost all of the 550W psu's are rated at 80+gold anyway.
If you're buying in Aus, Corsair or BeQuiet would be a good pick. You can only buy BeQuiet units from PCCG in Australia though, as they're the only authorised supplier in Aus.
Corsair RM550x = $140 AUD
Corsair TM550x = $120 AUD
BeQuiet Pure Power 10 CM = $100 AUD
BeQuiet Straight Power 11 = $160 AUD
The Straight Power 11 would be somewhat comparable to the RM550x in terms of quality (both Tier 1 on LTTs PSU tier list)
The Pure Power 10CM would be somewhat comparable to the TM550x in terms of quality (Both Tier 2 on LTTs PSU tier list)
For that system I'd personally go with the BeQuiet PurePower 10 CM for $100 as it's the best value and it's going to be more than capable of handling a GTX 1060 + Ryzen 2600X.
