No Power Pin 750 ti on PCIE x8?
Solved by Sakkura,
All the power pins in PCIe slots are in the little section on the left side, which is there regardless of the size of the slot. It's only the right side that varies, and all those pins are for data transfer.
You can see the pinout on wikipedia.
Featured Topics
RevGAM ·
Posted in Member Reviews0 -
1
ColossusRev ·
Posted in New Builds and Planning2 -
Trembletop ·
Posted in Graphics Cards3 -
2
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
