Will it bottleneck?
Solved by Tetras,
They're fine together. For ITX? Not ideal, you'll need decent cooling (CPU & inside the case), but doable? Sure. You'd likely get a lot of benefit from undervolting/power limiting the CPU and GPU, depending on the cooling capacity of the case you choose.
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
