Mini Generator for PC?
Go to solution Solved by PlayStation 2,
A UPS?
2 minutes ago, Hi P said:
I'm thinking of something like:
PC > PSU > Mini Generator > Outlet
So say if power goes out you could turn off the computer safely, is there such thing? just wondering
Thanks!
As said what you would want is a UPS what are your system specs we can better determine what you need for your system.
-Moved to Case and Power supplies-
https://linustechtips.com/topic/967448-mini-generator-for-pc/#findComment-11710247
It's called a UPS.
Cyberpower makes good ones.
My PFCLCD 1500 actually works with windows and behaves like a laptop battery, so if power goes out it will automatically shut down the computer at a set battery percentage.
You can also do stuff like limit performance/power usage when on battery, and other stuff, just like a laptop would.
https://linustechtips.com/topic/967448-mini-generator-for-pc/#findComment-11710264
I don't have my parts yet, but it's nice to know there is such thing, I'll ask for help on picking one once I have my build :)
Thanks guys!
https://linustechtips.com/topic/967448-mini-generator-for-pc/#findComment-11710271
