Hey guys I was just wondering how fans are suppose to be placed inside of a case to get them to push and pull , im getting a little confused. I will be putting my x62 at the front of the case with the fans at the front of the aio (So on the right side if your looking straight at the case through the window) My question is what way do you want the fans to face? is the logo suppose to face the case? or the aio. I will also have the other 3 fans which came with the nzxt h700 on the top as exhaust but again does the logo face towards motherboard? or towards the top
Thanks
My parts: https://pcpartpicker.com/list/6nbJgw
https://linustechtips.com/topic/966647-fan-placement/
Fans blow air from the logo side to the specification side.
Desktop benching:
https://linustechtips.com/topic/966647-fan-placement/#findComment-11703028
5 minutes ago, Blindeagle said:
Should i be putting the Aio at the front or top? after doing some research ive been told the front is the best but maybe you could advice?
If I were you I would put the radiator on the top. That helps the graphics card get cooler air
Desktop benching:
https://linustechtips.com/topic/966647-fan-placement/#findComment-11703061
Just building my new pc and was wondering were i should put the x62 aio? Front or top? Some people tell me the top some people are telling me the front etc:
I watched this video and it said to put it at the front because its the best overall but i wanted to double check with you guys about it
Pc Parts : https://pcpartpicker.com/list/6nbJgw
https://linustechtips.com/topic/966647-fan-placement/#findComment-11704487
I tried using the stock fans as a push @ front compared to a push @ top.
Seems like the cpu is cooler with fans at the front.
And with added pull fans at the front, i managed to cool down my gpu even further.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/966647-fan-placement/#findComment-11704500
Ah so put the AIO at the top with air geting pulled into the case from the front? and then pushing it out at the top?
https://linustechtips.com/topic/966647-fan-placement/#findComment-11704503
I always put it in the front just to be safe
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/966647-fan-placement/#findComment-11704519
1 minute ago, Blindeagle said:
Just so i get it, do the fans have to be on the right side of the aio at the front? with the logos facing out? to pull air in
It doesn't matter as long as the fans are pulling air into the case
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/966647-fan-placement/#findComment-11704523
H.jpg&key=e6aa55733e4b77e4d3c2333896d62c
https://linustechtips.com/topic/966647-fan-placement/#findComment-11704571
Hey guys i just wanted to check, Im putting my Rad at the front with the fans and wanted to double check that air is going to get pulled in? Is the logo on the correct side? Or is it suppose to be the other way around. Image attached below
My parts : https://pcpartpicker.com/list/xBwBzY
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706262
@Blindeagle Air blows the direction those NZXT logos are facing.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706271
Just now, seon123 said:
Those fans are set to intake air.
Ah thats perfect then asI 'm putting my Rad on the left side of the fans, i want air to be sucked in and then it will go out of the top of the case and rear
Or am i going coo coo and got it the wrong way?
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706291
That's correct
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706300
Yeah, you had it the way you wanted it.
Be careful that your exhaust at the top of the case doesn't cannibalize the intake air from the front. You don't want it exhausted before it actually gets to your VRM/RAM/etc.
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706303
Ye i think i will try and have 2x140mm as intake and then at the top i will have 3 exhuast and 1 at the back and just lower the rpm of them so it matches the 2x140 see how that works , i think it should be fine
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706326
pc fan have two arrows  one point the spin direction the other where the airflow go
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706391
Yeah, the fun part is creating setups and then testing them until you can find the ideal solution for your particular rig.
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706454
Hi I Just wanted to double check i put the krarken x62 3 pin connecter in the right place: I put it in the CPU_FAN 4 pin slot but you can see 1 pin is missing is that ok? Or have i done it wrong, thanks
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706489
The extra pin is for PWM only.
https://linustechtips.com/topic/966647-fan-placement/#findComment-11706512
