Hi Guys
When connecting the resovoir to the pump is it recommended to use a small amount of tubing or just use a M-M adapter?
As my last pump was a combo unit im not 100% sure.
EKWB EK-XTOP Revo D5 PWM +
EKWB EK-RES X3 400 Reservoir (3831109841037)
Thanks Guys
3800X, Corsiar 32gig 3200mhz LPX, Asus Hero X570. 2080ti black edition
https://linustechtips.com/topic/966367-connecting-res-to-pump/
Whatever you want.
https://linustechtips.com/topic/966367-connecting-res-to-pump/#findComment-11700274
9 minutes ago, kiwibacon said:
Hi Guys
Thanks Guys
Either will work.  The most important thing is to make sure the pump is beneath the res and you never run it dry.
https://linustechtips.com/topic/966367-connecting-res-to-pump/#findComment-11700275
