Case fan optimal setup
Solved by Origami Cactus,
1 minute ago, ValKK said:That basic principle didn’t cross my mind at all for some reason. Thanks a bunch though, will do that. As a side note, do you think reversing the 140mm at the back to get a fresh stream to the cpu rad would be a good idea? Or should i keep it as exhaust?
Just keep it as an exhaust, gpu heat also needs to get dumped out.
the 200mm fans have double the airflow as 140mm ones, so it will be good.
