Optane on already excisting system?
37 minutes ago, AT0MAC said:im not touching my nvme drive, its just for boot and programs, im only talking about either boosting my old spinning wd black or replacing it with a newer sata based ssd instead - difference in price is somewhere between double or triple the price, if i invest in the ssd instead of a 32-64gb optane
AFAIK your performance gain will be minimum as you already have an SSD.
If you want to game, go for a bigger SSD to add games to. If you want to benchmark/have specific server/encoding needs, an Optain *may* be faster.
PS, I just put small games (indie 2d etc) on spinning rust, and anything else on SSD. Else put rarely used games on rust, and common games on silicone. I Know Optain does this automagically... but really, why the price/storage limit when AMD (or $30 for software) will do it for free/$30 forever.
Optain is a server solution, it is a general computing solution that needs motherboard/DRAM/HDD controller integration. It's current system/setup is just pointless (like early SSDs that were smaller, slower and more expensive, more failure prone etc on release, but LATER became amazing tech).
