Architect 2018 build advice
6 hours ago, Raytheon said:
Good shout! Spent time today looking up Adobe & Autodesk suite core usages, the general consensus being (for my level of work) multi-core but pointless beyond 6 - 8 with recommendation being to spend money on ram and ssd over cores. (Unless heavy rendering which was more the merrier / 3D models being more ram based over cpu hence 64gb future upgrade). So it'd come down to higher clock speed vs more cores?
Thinking single largish M.2 boot + suites with SSD project storage. Nice spot on the PSU (+£160ish), my budget is flexible to a few hundred if needed. Cheers for the reply, really got me thinking, thanks!
@Jurrunio
Thanks bud, 3200 seems to be peoples sweet spot for DDR4 and folks saying its harder to push to full clocks? Do love the shiny but I fancy dipping a toe in the RGB, see how it looks. Want to see if I can pull off making lightning controllers work (BS excuse I know but it's Friday) cheers.
https://uk.pcpartpicker.com/list/ftzZXP
CPU: Intel - Core i7-7820X 3.6GHz 8-Core Processor (£433.98 @ Ebuyer)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler (£137.99 @ AWD-IT)
Thermal Compound: Innovation Cooling - ICD24 4.8g Thermal Paste
Motherboard: Asus - STRIX X299-E GAMING ATX LGA2066 Motherboard (£289.99 @ AWD-IT)
Memory: G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Memory (£377.04 @ More Computers)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive (£83.94 @ Aria PC)
Storage: Samsung - 970 Pro 512GB M.2-2280 Solid State Drive (£198.97 @ More Computers)
Storage: Western Digital - Black 1TB 2.5" 7200RPM Internal Hard Drive (£58.96 @ PC World Business)
Video Card: Zotac - GeForce RTX 2080 8GB GAMING AMP Video Card (£819.95 @ Overclockers.co.uk)
Case: Corsair - Crystal 570X RGB ATX Mid Tower Case (£154.79 @ Aria PC)
Power Supply: Corsair - 860W 80+ Platinum Certified Fully-Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit (£99.99 @ Amazon UK)
Total: £2655.60
Generated by PCPartPicker 2018-08-25 07:06 BST+0100
This is an 8 core Skylake-X build. The clocks are still pretty good, but, if your programs ever start leveraging the extra cores better, this has more room to leverage those cores. In theory, your workflow really should leverage AVX2 a lot better, but, as we've encountered, Adobe products need a lot of help.
Main thing is you'd get access to more PCIe lanes for NVMe storage, if it'll help your work.
Getting the Uncore overclocked should eliminate most gaming bottlenecks. It doesn't need that much of an OC to get through some gaming issues, but a few tweaks can unlock a bunch of performance.
