Weird process using 50% of my cpu
Solved by ciprian97pop,
10 hours ago, Syntaxvgm said:Its a system process but a little more jamaican
10 hours ago, Enderman said:It's literally a part of the security to prevent malware...
If it's using 50% CPU then there some problem with the OS.
Usually in cases like these you can leave it for a few hours until it finishes whatever it's doing and then goes back to 0%, but sometimes stuff gets stuck if you try forcing it to terminate or other reasons.
10 hours ago, emosun said:that... really makes me not want to use windows 10 lol
Hi again
So... yeah..
Today I installed malware-bytes and let's just say that that wasn't a windows event reporter
Again, thank you guys for your involvement
