How to fix High Clock at idle? (causes fairly high temps with no usage)
Solved by Dayfly,
For anyone that stumbles across this, it might just be one specific process running in the background causing this. I have Solidworks visualise installed on my pc and it has a background process “SWVisualize.BoostService” which immediately after forcing it to stop drops the memory clock to a more reasonable number.
So you should look through your running programs and see if there are things you can kill which might be the culprit.
Featured Topics
1
tippytipper ·
Posted in Storage Devices1 -
2
AlyShazli ·
Posted in New Builds and Planning17 -
4
Emmanuel Katto ·
Posted in Peripherals3 -
3
3
Rusty Proto ·
Posted in Programs, Apps and Websites0
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
