Will this work well
On 8/19/2018 at 5:56 AM, MrSuper said:I need to run an Ethernet connection and improve the WiFi signal in an area of my house. It's around 30m away from the router. I have a gigabit connection. I'm going to have my PC in that area soon so I will need Ethernet so my PC can utilize the full gigabit download. Also I'll need an Ethernet WiFi extender to transfer the data reliably to other devices nearby.
What is the best, cheapest and most efficient way of having this done, while only running one 30m Ethernet cable over there?
Is there a product that can act as a WiFi extender as well as an Ethernet passthrough?
Any advice greatly appreciated.
Honestly here are the options I would consider.
1) Run the cable and connect it to a WiFi router in AP mode. The LAN ports should be able to work and you will have wireless
2) Run the cable and connect it to a switch and buy a separate AP.
3) Option 1 or 2 but use a power line adapter to get the wired connection where you need it.
4) Option 1 or 2 but use a moca adapter to get the wired connection where you need it.
