Best 144hz monitor
Hamface55
Hello,
I am looking for a good but cheap 144hz monitor. I don't really have a budget but wanna get something that is cheap. Something that I can use for years. I have been using a 60hz for awhile and really wanna upgrade.
Thanks,
Dylan
for advice on buying hardware please always include budget or price range.
in addition were talking about monitors so the following additional preferences should also be adressed:
Display size
Display Panel ( TN or IPS )
G-sync or Freesync
Preferred resolution.
with these parameters we can give you a solid advise.
( sorry to make it sound lika an ad XD)
Positive Mental Additude!
Just another Tired IT guy...
