I just have a quick but obscure question regarding the Wraith Spire cooler.
Does the fan blow air down towards the motherboard or up away from it?
I can't seem to find the answer anywhere and I don't have a ryzen to test it myself yet. I need to know if it will compete with my power supply for airflow in a sff system where the psu is directly above the socket.
Thanks! :)
Lineage - My First PC Build and Mod
Check it out on pcpartpicker.     1700x | Evga 780Ti | Modded Lian-li Lancool One Digital
PSU Tier List | PSU Calculator | 80+ Guide | Graphics card (cooling) tier list | Motherboard Tier List | Linux Guide | Before troubleshoot | Mark Solved | Community standards
https://linustechtips.com/topic/960761-wraith-spire-fan-direction/
Thanks!
looks like I'll be buying an after market cooler..
4 hours ago, rev_dude said:
Thanks!
Its working just like all other downdraft coolers. Even aftermarket ones. Its much more effective that way as it cools chipset at the same time. Plus, there isn't any fans directing air to that area so that fan would be effective when its other way.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
there is no competing for airflow happening there, this setup used to be how every PC was running like a decade ago.
