3 minutes ago, romeoarts said:
is this worth the 700 dollars ??
  • Mid Tower Chassis
  • AMD Ryzen 5 2400G
  • Radeon RX Vega 11
  • GB DDR4 Memory
  • 2TB 7200RPM Storage
  • Premium CPU Cooler
  • 600W Power Supply
  • A320M Motherboard
  • Windows 10
No if it's USD. That's a pretty big rip off. What currency? And what's with those icons that take up space?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640444
-Threads merged and moved to New Builds and Planning-
Please refrain from reposting content.
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640460
5 minutes ago, romeoarts said:
can u recommande something around 800 dollars that's good for gaming ?
What games and what settings? That's already a pretty good setup for light gaming. It's just that you can get a far better price for that specification.
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640477
looks like i should be going with the level 2 verison of it with ...
  • Mid Tower Chassis
  • AMD Ryzen 5 2600
  • GeForce GTX 1050 Ti 4GB
  • 8GB DDR4 Memory
  • 600W Power Supply
  • B350M Motherboard
  • Windows 10
Edited by Crunchy Dragon
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640489
why the giant icons.... mod please fix.
Otherwise things like the cpu cooler/case/gpu aren't very descriptive which means they are probably junk so no i wouldnt pay 700$ for anything that wasn't very descriptive.
edit : i also just noticed the power supply has no info either so very much not worth 700$
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640514
sorry for the icons im copy pasting and the 1000 dollar version seems better >??
  • Mid Tower Chassis
  • AMD Ryzen 5 2600
  • 8GB DDR4 Memory
  • 600W Power Supply
  • B350M Motherboard
  • Windows 10
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640525
stop doing that then or get rid of them.
again no , nothing in this information is very descriptive about what the parts are. if the seller isn't ashamed of the parts they chose then they would say what the parts are. so IDK where you are shopping but stop shopping there.
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640551
-Threads merged again-
Refrain from reposting content. Also please avoid large icons.
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640576
I'd pay max 350 for that build
A320 board
2133 mem
cheap ass case with bundled psu I doubt IRL is more than 300W
"premium CPU cooler" heh didn't knew the stock was called that way nowadays
they're probably charging you over $100 just for windows home edition
0/10
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/959720-i-need-help/#findComment-11640845
  • Mid Tower Chassis
  • AMD Ryzen 5 2600
  • 8GB DDR4 Memory
  • 600W Power Supply
  • B350M Motherboard
  • Windows 10
No. Any $1000 build without a SSD is a terrible build.
https://linustechtips.com/topic/959720-i-need-help/#findComment-11641066
  • Mid Tower Chassis
  • AMD Ryzen 5 2600
  • 8GB DDR4 Memory
  • 600W Power Supply
  • B350M Motherboard
  • Windows 10
That's worth $650 at most. Stop creating multiple threads, you're wasting the staff's time.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/959720-i-need-help/#findComment-11641088
