16 minutes ago, FlyToMoon said:
use air cooling rn
The Coolermaster H500P Mesh or the H500M; The Silverstone PM01 TG and Basically all Coolermaster Master 5 Cases would fit your Aircooling needs and make the most out of your Budget.
They're also well suited for AIOs
The 750D suggested by @DaPhuc, altough an older case, is also a good candidate.
RGB & Fan control ULTIMATE GUIDE !
@FlyToMoon Meshify C and Phanteks Pro M / Special edition (white interior) are my recommendations for excellent airflow and quality for the price.
Best & worst cases for your money in 2018 are:
Best Cases overall
I) Fractal Design Meshify C - Airflow and relatively quiet, best all around case
I) Phanteks Enthoo Pro M / Special Edition (white interior) - Airflow & full water cooling support
I) Fractal Define R6 - Silent with decent airflow
I) Be Quiet! DB 900 (Full Tower) - Airflow and silent
I) Fractal Design Meshify C mini (mATX)
I) Corsair 400C - Only use with low end components, no 1080 / TI
I) Phanteks 350X - Only use with low end components, no 1080 / TI
I) Fractal Design Focus G
Cases that may be worth your money
I) Thermaltake G21 - GPU and CPU cooling issues, modest tweaking
I) Silverstone RL06 / Pro - Mustard/Ketchup wires, Shitty cable management, Poor front radiator support, useless psu filter, stupid ssd layout
I) In Win 303
I) Coolermaster H500 no suffix - if 200mm fans are your thing
I) NZXT H700 non "i" version - Needs to come down in price to be worth it
I) Corsair Carbide 100R - Suitable for low end builds
The worst cases - Do Not Buy
I) NZXT S340/Elite, H500, H440 (everything except the H700) Reason: Poor airflow
I) Coolermaster Masterbox 5
Majority of cases on the market
22 hours ago, FlyToMoon said:
budget 200 usd
use air cooling rn but im also planning to *maybe* upgrade to aio
so what case do you guys recommends
Whats the rest of the system? (How tall is your current air cooler, How many hard drives do you have, What's the length of your GPU, etc)
