Mechanical or membrane?
Best & worst cases for your money in 2018 are:
Best Cases overall
I) Fractal Design Meshify C - Airflow and relatively quiet, best all around case
I) Phanteks Enthoo Pro M / Special Edition (white interior) - Airflow & full water cooling support
I) Fractal Define R6 - Silent with decent airflow
I) Be Quiet! DB 900 (Full Tower) - Airflow and silent
I) Fractal Design Meshify C mini (mATX)
I) Corsair 400C - Only use with low end components, no 1080 / TI
I) Phanteks 350X - Only use with low end components, no 1080 / TI
I) Fractal Design Focus G
Cases that may be worth your money
I) Thermaltake G21 - GPU and CPU cooling issues, modest tweaking
I) Silverstone RL06 / Pro - Mustard/Ketchup wires, Shitty cable management, Poor front radiator support, useless psu filter, stupid ssd layout
I) In Win 303
I) Coolermaster H500 no suffix - if 200mm fans are your thing
I) NZXT H700 non "i" version - Needs to come down in price to be worth it
I) Corsair Carbide 100R - Suitable for low end builds
The worst cases - Do Not Buy
I) NZXT S340/Elite, H500, H440 (everything except the H700) Reason: Poor airflow
I) Coolermaster Masterbox 5
Majority of cases on the market
Seeing as you just got into PC gaming, you may be under the impression that a "gaming" keyboard will make you better.  Understand that this is simply not true and is a marketing gimmick.  If you are not bothered about a mechanical keyboard, don't get one.  You're current budget I'd say is around €10 over the minimum for a decent quality budget mech.  Most mechs over that price point should be pretty sturdy and will last you a good amount of time.  @geo3's suggestion (the Redragon Kumara) is a great keyboard, I would look into that.
