I need help in picking a GPU
4 minutes ago, jonrosalia said:if you can wait im thinking a lot of good sales should be coming with the looming drop of the new cards on the 20th and you might get a great deal on a next tier up card getting that 1070 for the price of a 1060. the 1060 6Gb is a solid card and does 1080 gaming all day but having the HP to be good for the next set of game launches in 2-3 years might be worth the extra cash up front to play at better settings and you never know you might be able to get a 144Hz monitor in the future look at it from how is this going to serve me in 5 years you have really good hardware to start with for a mid tier build might as well throw the best card you can afford into it to try to keep from buying another one also you can add another 1070 in sli you cant do that with the 1060 if you do end up needing more power down the road.
Do you have something i can talk to you in private? Steam Discord or something ?
