If I linked the modal would toy tell me what is wrong???
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/954986-i-made-a-case/
10 hours ago, Sernefarian said:
Link the model to it please. I'm pretty interested, and perhaps some people with more knowledge of case design could give suggestions or advice.
I protocase format ok???
https://linustechtips.com/topic/954986-i-made-a-case/#findComment-11601649
screenshots perhaps ?
https://linustechtips.com/topic/954986-i-made-a-case/#findComment-11601746
https://linustechtips.com/topic/954986-i-made-a-case/#findComment-11602239
2 minutes ago, Edward78 said:
Might just want to screenshot the Protocase designer. This is what I get when opening the IGES (a type of universal 3D file) in Inventor,m, something not everyone has access to...
https://linustechtips.com/topic/954986-i-made-a-case/#findComment-11602254
What's up with that??? That is not at all how it looks,,, Ok got to go back to windows, got to log now... Later tonight??? Protocase is free if you want to try...
https://linustechtips.com/topic/954986-i-made-a-case/#findComment-11602267
I figured it wasnt.. It looks like some of the surfaces didnt get properly translated to the universal file (there's multiple sets of PSU and PCI-E bracket cutouts for example) Sadly I cannot access that program (or download it) from my work computer, because, it's a work computer and as such is controlled by my IT
https://linustechtips.com/topic/954986-i-made-a-case/#findComment-11602346
Home computer?
https://i.imgur.com/donWJHc.jpg shot of back...
https://linustechtips.com/topic/954986-i-made-a-case/#findComment-11603934
