Bitfenix Alchemy LED Strips, i just bought them and they are amazing
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/95464-led-modding/#findComment-1278230
They also have the features i listed?
The only features that they have is that they can attach anywhere in your case and also can be daisy chained together. The colors they have look great.
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
https://linustechtips.com/topic/95464-led-modding/#findComment-1278262
Bitfenix Alchemy LED Strips are extremely expensive for what you get, and I'd never recommend them to anyone that has a modders mind and/or knows how to solder. ~$30+ for a 2ft strip is absolutely ridiculous.
For the same exact price, you can buy a 16.4FT strip that has an IR remote and power supply, such as this roll from Zitrades on amazon (I bought this exact strip): http://www.amazon.com/gp/product/B00A2MD5Y4/ref=oh_details_o01_s00_i03?ie=UTF8&psc=1
You also get twice the LEDs per foot (18 LEDs per ft vs 9 LEDs for the bitfenix), you can control the color and brightness, and the strip is extremely easy to cut apart and mod into multiple strips or for use in your computer. For my computer, I have 3x 6 inch strips all wired up to molex. Of course if you wire them to molex you won't be able to change colors or the brightness, but there are 4 copper tabs shall we call them. +12V, red, blue, green (not in that exact order, plus different RGB strips have different orders sometimes).
Hope this helps, plus the images below :)
::Click to Enlarge::
https://linustechtips.com/topic/95464-led-modding/#findComment-1280208
I also use Bitfenix Alchemy LED Strips, check my build log for pics of it: http://linustechtips.com/main/topic/36288-the-cube-cooler-master-haf-xb/
CPU: AMD FX 8120 @4.5Ghz - CPU cooler: Cooler Master Nepton 240M Watercooling - Mobo: Asus M5A97Pro - GPU: Sapphire Radeon R9 280X Vapor-X @ 1200Mhz - Memory: Kingston Hyper X 16GBs DDR3 - Storage: Kingston SSD & Seagate Baracude HDD - PSU: Cooler Master V850W PSU- Case: Cooler Master Cosmost II
-- Build Log old PC (HAF XB): 'the Cube': http://linustechtips.com/main/topic/36288-the-cube-cooler-master-haf-xb/ --
https://linustechtips.com/topic/95464-led-modding/#findComment-1281895
I am looking for single color leds for in my case, and another led strip which i can somehow attach to the ceiling in my room, which has dimming, color managing and all that fancy stuff with a wireless 'controller'
-a good post-
I'd reccomend to make a DIY  controller with an Arduino and a cheap RGB LED strip ordered from China.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/95464-led-modding/#findComment-1281942
