As long as the active/current temps are within reason, it's fine. Keep an eye on the updated temps every second or so.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596278
I would check what the temp in the BIOS says. If it's idling in the ~50°C in the BIOS then I'd go at the CPU with a can of compressed air & fresh thermal compound.
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596281
These ones below, I don't know if your hardware monitor has a similar setup, but for me, HWMonitor has the columns as Value, Min, and Max.
The Value column updates every 0.5 seconds or so to give the accurate, real-time temperature. Make sure these are all within margin of each other and it's fine.
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596297
can you upload screenshots with all the temperature readings instead?
Desktop benching:
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596300
This is what I'm talking about
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596318
eh, just ignore that sensor in the 4th core. It's broken. You cant have that big of a temperature difference in the same silicon.
Desktop benching:
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596325
17 minutes ago, Nyxify said:
Also in the bios it said my pc was at 69 to 70 degrees celcius. Is that good for being idle?
it's bad, but I guess the bios just averaged out the temperature readings and spit the number out.
Desktop benching:
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596384
2 minutes ago, Nyxify said:
Wait so do I or do I not need to worry about it?
Probably not, the rest of the cores are fine, so no need to worry.
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596405
I wont be worried. To be safe, just keep HWmonitor running while you do other things, and make sure the other temperature readings dont read something abnormally high for your cooling setup.
Desktop benching:
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596407
My CPU Core is hitting 95-100 when gaming, I really need help to fix this.
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596464
even the sensors other than that in Core #4? then you really have a problem. What cooler are you using?
btw, CPU package usually refers to the sensor on your CPU socket, not on the CPU itself. the actual temperature in the CPU will be higher than what the package temp is as a result.
Desktop benching:
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11596508
So I'm using the LE Grand Macho RT, me and my mom re installed the heatsink last night, and it was working fine after. But what I didn't notice until this morning was that my mom flipped the heatsink fan around. Now the fan isn't facing the same way as it shows in models in other builds and such. But it drastically decreased my cpu temp it'w now running at 31-34 C Idle and 45 C when playing csgo.
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11597934
is the fan pushing air towards the heatsink now?
Desktop benching:
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11598110
I believe so
that's the right way to put it, so using the fan the wrong way is the culprit :P
Desktop benching:
https://linustechtips.com/topic/954569-cpu-overheating/#findComment-11598188
