8700k 5.1 oc - 1.385v
gtx 1080ti oc to 2088/6011
custom loop with 2 240 slim radiator and d5 pump
And 16gb g skill ram+Asus hero x
for now I have 750w Corsair
how much psu is required if I’m adding more 1080ti so it will be sli of 1080ti oc
And 8700k at 1.385v v
https://linustechtips.com/topic/954127-how-much-for-sli/
Just now, Adab5 said:
Waste of money to get SLI, just save your money for the soon to be released 1180ti or Radeon Navi 4 die mega ultra GPU that probably won't exist.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11592672
2 minutes ago, Adab5 said:
It’s for benchmark perpes.
Then get some crazy high end Platinum 1200W unit with near perfect voltage regulation?
Or buy that 1600W unit if you're going to run 4GPUs off one PSU? Or just use 2 PSUs at that point I guess.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11592704
Someone already pointed out how much of a waste it is to go SLI these days, but since you asked...
With OC's that sky-high I would probably go for an 850W unit. Should leave you headroom if you want to benchmark two Titans as well.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11592782
SLI is dying. It offers little performance gains in games that support it. In most other games, it'll see diminished performance, downwards to a 30 FPS decrease.
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11593135
Don’t see what any of that has to do with what he asked. Sli talk from a bunch of plebs.
I myself would upgrade the unit. Would really prefer platinum and something that rides well in the 70/80% range while still being quite.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11594180
30 FPS decrees? Are you sure
i’v been Told that I maybe gain more 15-30 fps in games and in worst case scenario I will have the “just one card fps”
but decress of up to 30fps from one card? That sounds very weird
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11595675
Not everyone that actually comments has used sli. So they parrot what someone else said. Even they person may not know what they are doing, so they blame what they can. A lot of things are overlooked so that tends to happen. Ive never had a decrease that could be blamed on sli. Other random issued would take that blame.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11595682
I had SLI gtx 570s, gtx 580s, and gtx 650 ti boosts. All of them scaled alright for the most part. I'd say on average each GPU was at 60-70% usage. But therein the problem lays, for example, in GTA V all of my SLI setups refused to go over 50% usage PER CARD, so thats "just one card fps", but then often the usage would drop to 40-45% PER CARD, so thats less than a single cards performance. Overall it was just a headache, but hey maybe im crazy and wrong because my cards were all old at this point.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11595706
I remember seeing benchmarks that some games see a decrease in performance. I believe it was ghost recon that saw a big decrease in FPS.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596183
@Adab5Get a platinum 1000W or higher. Either in rating or power. You don't wanna be the one guy posting about an SLI rig with a tiny PSU. That's like skipping leg day, my friend.
@Streetguru You realize being the first person to tell an OP their idea is dumb instead of answering their actual question is kinda dickish right?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596197
He didn't say it was for benchmarking and not gaming
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596210
You can power two 1080 tis with an 8700k with a 650 watt PSU. According to PCPP wattage calculator it estimates almost 700 watts, which is obivously way off because PSU calculators are trash. Under normal gaming loads, the power draw is likely closer to 300-350 watts because I don't know of any game that will cause both GPUs to run at 80-100% load. 650 watt PSU is fine, but, I would recommend a 750 PSU instead.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596213
Doesn’t matter what’s it for. Not everyone wants to lower their gameplay.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596214
27 minutes ago, QuantumElement said:
If you're running any kind of dual GPU system you'd want to start with a good 1000W Unit
for trying to hit benchmarking records you probably want something higher end than that.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596262
Let's say absolute best scaling scenario - 1080Ti SLI with both GPUs pinned at 100%, that's 600w there, CPU is a further ~100w, that's still plenty of space on an 850w... 1kW only makes sense for SLI + HEDT or 3-way SLI...
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596292
You don't want to run your PSU at the limit and if you can afford 2 1080tis you can easily afford a $200-$300 PSU
That's also not counting any volt mods which probably runs it closer to 400W.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596299
OP didn't mention voltmods, also there's nothing wrong with running your PSU at 90%, that's entirely a myth...
PCs:
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596310
You also understand that certain people like to operate within a certain range of their PSU and not simply using it at its max. Which is what someone might do with a 650W or 750W. Think of driving a car and driving it at a constant high RPM as opposed to finding that car's ideal power band with its RPM range. That is kinda what people do with PSU's.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596326
Just now, nick name said:
You also understand that certain people like to operate within a certain range of their PSU not simply that using it at it max. Which is what someone might do with a 650W or 750W. Think of driving a car and driving it at a constant high RPM as opposed to finding that car's ideal power band with its RPM range. That is kinda what people do with PSU's.
Except there's really no benefit to doing that, PSUs are designed to be able to output 100% power 24/7 for extended periods of time...
PCs:
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596329
Sure there is. Fan noise is one thing that comes to mind.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596331
Fan noise is irrelevant of PSU total wattage, don't think of load as a % of total wattage but as a flat number, if your PSU is 90% efficient then it doesn't matter if it's an 850w pushing 800w or a 1000w pushing 800w, it still has to dissipate 89w of heat...
PCs:
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596344
And neither did you.
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596348
Do you really think the components inside a 650W and a 1200W PSU dissipate heat at the same rates?
https://linustechtips.com/topic/954127-how-much-for-sli/#findComment-11596353
