AMP draw of Bitfenix spectre pro and corsair RGB LL140
14 minutes ago, grimreeper132 said:The corsair fan draws 0.3A
The Bitfenix fan draws 045A (+-10%)
Also the corsair one has a higher RPM, and so I suggest that one personally, and all the currents are nominal values, meaning the actual current for both might spike above them, depending, e.g. when you first turn it on it might draw an amp to start spinning. General rule though, all fan headers support all fans, if the fan can draw 2A, but only can get 1A, then it will only get 1A, cause that's all it can be supplied to it.
If you want to find this out in the future just google the fan and look at the tech specs.
https://www.corsair.com/uk/en/Categories/Products/Fans/ml-config/p/CO-9050073-WW
https://www.bitfenix.com/global/en/products/accessories/spectre-pro-rgb
i found the running ampage but i coundnt find the start up ampage. Also is it true that if the fan takes more than 1 amp from the header it will burn it out(saw on tom's hardware)
