I'm building a 2200G system in  a rvz 01.
Does the cpu come with a cooker, will it fit into the rvz01?
If not what cooler should I get
Thanks
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
https://linustechtips.com/topic/952533-cpu-cooler-for-2200g/
Thanks
Yes it includes a cooler, I'd suggest just using that.
Share any interests with me? Feel free to message me just to chit chat about whatever.
(Music) Depeche Mode, The Cure, Pink Floyd, Nick Cave and the Bad Seeds, Cocteau Twins, MGMT, Boy Harsher, The Smiths, Drab Majesty, Chelsea Wolfe, Carly Rae Jepsen, The Smashing Pumpkins, Virgin Prunes, Sky Ferreira, London After Midnight, Jonathan Coulton, Alvvays, Clan of Xymox, Bauhaus, Siouxsie and the Banshees, Anna Von Hausswolff, Joy Division, Sisters of Mercy, She Wants Revenge, The Frozen Autumn, My Bloody Valentine, Type O Negative, The Birthday Party, Leonard Cohen, Switchblade Symphony, Metallica, Creedance Clearwater Revival, Eagles, Elton John, Billy Joel.
(Games) PUBG, Metro Series, Command and Conquer games, Warhammer 40,000 games, Company of Heroes (2), RDR2, CoD4
(Other) Going to the goth club, Firearms, Building PCs (Especially budget PC builds), Playing instruments (Guitar, Piano APP for PC, Otamatone, Trombone) Camping, Board Games
https://linustechtips.com/topic/952533-cpu-cooler-for-2200g/#findComment-11578189
the case has 83 mm which is very tall for an itx vertical case like that so even the wraith spire will fit if you're super concerned with thermals. But there are better options if you do want to
You will be able to overclock your cpu with the wraith stealth but only a little bit.
for example, I used the wraith stealth on my 1500x and got 3.8ghz at 1.26v at 80 degrees load which is good for that tiny cooler. Because its an APU it'll obviously run hotter because of the graphics part but if you are wondering about the thermal performance of the cooler it is a very good cooler for the size and quiet.
https://linustechtips.com/topic/952533-cpu-cooler-for-2200g/#findComment-11578669
