Best case for temp and silence (6x hdd, 1x 5.25)
Solved by TVwazhere,
1 hour ago, MiChAeLoKGB said:there might be something better than Define R6 and I just dont know about it.
IMO, there's not much better than the R6 for your needs. Better silence than the 750D and better airflow than the be quiet!. It's kinda the best of both worlds, not as good as either case but strikes a good balance. Plus it's the smallest of all the cases listed in this entire thread. (Maybe not the HAF 912)
