3 minutes ago, Sakif said:
is cooler master 450w mwe ok for rx 580 8gb or not?
Welcome to the Forums!
Depends on your other components in the system but in general that would not be recommended as that PSU is a very entry level unit. Your going to want to upgrade the PSU before other components in the system.
-Moved to Case and Power Supplies-
https://linustechtips.com/topic/948564-power-supply/#findComment-11541803
Not recommended? What other choices do you have?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/948564-power-supply/#findComment-11541805
depends what other components you have, that PSU would be ok-ish with a CPU that's up to 95W, an SSD and a single 7.2k HDD
there are better units though
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/948564-power-supply/#findComment-11541811
So, a 8700K, a 2TB HDD and a 12TB hard drive?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/948564-power-supply/#findComment-11541820
1 minute ago, ThatFrizie said:
i’d say get a 550 or a 650 one
Wattage isn't all that matters...
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/948564-power-supply/#findComment-11541891
the 8700k has higher TDP, the SSD would use like 10W and the hard drive 15W
https://linustechtips.com/topic/948564-power-supply/#findComment-11541894
https://ark.intel.com/products/126684/Intel-Core-i7-8700K-Processor-12M-Cache-up-to-4_70-GHz
"TDP: 95W"
The SSD will use more like 4W, and the hard drive maybe 6W. Negligible.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/948564-power-supply/#findComment-11541898
I know but i was just talking about the general wattage that would be good
PC specs:
I7 8700
1x 8gb Ballistix Elite 3200MHZ
MSI Gaming Trio RTX 2080
G650M PSU
120gb Kingston SSD
3TB of HDD
NZXT S340 elite Black/Red
https://linustechtips.com/topic/948564-power-supply/#findComment-11541906
350w would likely be enough...
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/948564-power-supply/#findComment-11541940
