Have you tried plugging it into a different sata header?
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/947682-help-please/#findComment-11534133
5 minutes ago, Daivon said:
The motherboard , cpu and psu
Then you probably need to reinstall windows.
I dont know what was your first platform from where you upgraded, but for example when i went from i5 6600 to r7 1700 i found out that i cant boot it, it bluescreened before windows could load every time. So i ended up reinstalling windows and then i could boot.
But before reinstalling install the drive to another pc and get all your valuable stuff off from there.
https://linustechtips.com/topic/947682-help-please/#findComment-11534150
Did you set your boot options to boot from your hard drive?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/947682-help-please/#findComment-11534154
Well i tried that , but.....
https://linustechtips.com/topic/947682-help-please/#findComment-11534155
If you got OEM Windows it be an issue as well, doesn't it tie itself to the motherboard?
@Some Random Member might know. Pretty sure that's how they used to do it.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/947682-help-please/#findComment-11534156
Format it?
https://linustechtips.com/topic/947682-help-please/#findComment-11534159
Should work regardless, taken my current installation between 3 systems so far: Core 2 Duo to Phenom X4 to FX 6300. Still boots fine.
https://linustechtips.com/topic/947682-help-please/#findComment-11534163
2 minutes ago, Daivon said:
Thats a pain in the ass , if i can solve it without formating would be nice
If you have another drive spare try cloning. Make sure the spare drive is larger ofc.
https://linustechtips.com/topic/947682-help-please/#findComment-11534173
I dont , im trying to format it ... its already taking too long
shouldve done it through gparted, its much quicker.
https://linustechtips.com/topic/947682-help-please/#findComment-11534182
You might have been able to enable CSM and boot it maybe. Anyway, no point in going there now.. make sure your windows installer drive is set to GPT/UEFI. I suspect it already is going by the error message you got, but just make sure.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/947682-help-please/#findComment-11534191
Well i already formated it but i dont know how to solve this
https://linustechtips.com/topic/947682-help-please/#findComment-11534225
Get EASUS partition master free version  https://www.easeus.com/partition-manager/epm-free.html
Select the disk and change it to GPT file system.
If you don't have an OS to use that on, then get gparted and put on cd/usb and boot, and do the same.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/947682-help-please/#findComment-11534246
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/947682-help-please/#findComment-11534248
I have no idea. I went from the i5 6600 to r71700 and ofc i had to change motherboards and it still the licence worked after reinstalling windows on a new mobo. (I accidentally bought the oem version of windows from amazon.) But i somehow had the licence tied to my windows account or something like that.
https://linustechtips.com/topic/947682-help-please/#findComment-11534255
