We need to know the CPU model name (say, i5 6400) because frequency and core count tell very little about the CPU's performance
Also, that 1050ti bought used?
Desktop benching:
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11522292
you could probably do with a better cpu as well. If you're on lga 1150, try to find an i5 4570, and if you're on lga1151, try an i5 7500. Both go really well with a 1050 ti, but you need a higher frequency to keep stuttering at bay.
And if you're using a core 2 quad, a 1050 ti might be a bit excessive.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11522321
38 minutes ago, Vonchi said:
Hello I have a low end gaming computer with a GTX 750TI and a quad core  Cpu  and saw a Gtx 1050ti  and was wondering if it would work and would u see improvement. My cpu is 2.5ghz
Probably best to get a modern CPU first given current GPU pricing. You'll be able to find cheaper GPUs soon enough anyways.
What's all your current hardware and your budget/country?
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11522365
Intel(R) Core (TM) 2 Quad CPU Q9300 @ 2.50GHz 2.50GHz  is this the info you need?
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11528493
A core 2 quad basically maxes out its performance with the 1050 ti, so I guess it's good. However, you might see an equal if not bigger performance increase with a better CPU. I did some testing with a core 2 quad and 1050 ti and found a newer CPU will probably help more than a newer GPU. Try to find an i5 on ebay, with a good motherboard to go with it.
Primary PC:
PSU tier list
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11528603
I would have to change the ram.the Power supply  but thanks will do
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11530885
Here is my advice for the best upgrade path.
Look for a used dell workstation. These are normally only 2 or so years old and are retired corporate machines.
So it would normally have a 4th gen i5 or i7 in it.
8gb of ram
A decent sized 7200rpm drive or maybe even an ssd (if not you can put an ssd in one for like 45 bucks for a 240gb)
some have a lower grade gpu or use onboard graphics
The thing though... is these can be found all day from $100-$200. So if you pick up one of these and then toss in a 1050ti you have a nice gaming machine for a $200-$300 investment.
There is always the option to build a new budget machine, but often times it will cost you more for a lesser system than my suggestion above.
Actually looking at ebay if you are willing to go a little older to second gen I7-2600's then you can get a machine like I mentioned above for about $50. So that would put you at 200ish WITH a gpu upgrade
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11530919
16 minutes ago, AngryBeaver said:
Agreed if you live in a country where these are common due to large business liquidations/etc.  The 2nd gen i7s seem to be the best value, but anything before skylake has the advantage of needing cheaper ddr3 ram.
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11530954
I live in the UK but will look around and see what I find ty all for the help and support
https://linustechtips.com/topic/946429-cpugpu-help/#findComment-11531878
