hey im new to the forums so do bare with me
im planning to build my first pc and i am worried if the components are not going to be compatible. here is the list of things im getting:
motherboard: asus maximus VI hero (z87)
cpu: intel core i5 4670k (z87)
gpu: asus Nvidia Geforce GTX 660 Direct CU II
psu: corsair cx 600
ram: corsair vengence 8gb
if their is any problems with this setup, dont be afraid to tell what is wrong with it, after all i am a noob when it comes to computers so help would be appreciated.
i also have a zalman z11 plus atx case.
https://linustechtips.com/topic/94628-my-first-pc-build/
psu: corsair cx 600
welcome to the LinusTechTips forums, i've moved your topic to the correct section for best answers
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268529
Use PCPartpicker as it'll filter out anything which isn't compatible usually. . .
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268531
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.98 @ OutletPC)
CPU Cooler:  Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  ($26.65 @ Amazon)
Motherboard:  Gigabyte GA-Z87-D3HP ATX LGA1150 Motherboard  ($109.99 @ TigerDirect)
Memory:  G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($76.98 @ OutletPC)
Video Card:  Asus GeForce GTX 760 2GB Video Card  ($239.99 @ Microcenter)
Power Supply:  Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($37.99 @ Newegg)
Total: $721.58
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-12-28 16:29 EST-0500)
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268532
Total: $721.58
wow thats alot i didnt thought it was going to be that expensive in american dollars but im British so i would say thats around the £550 which is still alot
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268586
Total: $721.58
Use this!
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268589
They're compatible but I'd dial down on the motherboard, you don't need that high end of a motherboard and invest that money on a better GPU like a GTX 760.
the motherboard and the cpu were kind of a problem because of the price but you are right
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268595
^what Nicholas Marzio said. Kingston HyperX are usually $20 cheaper. Also try a different board like a MSI G45 Gaming for example. This could save you enough to pony up for a GTX 760
i didnt think to go a different mobo. i geuss i like asus more than msi :)
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268603
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£173.94 @ Scan.co.uk)
CPU Cooler:  Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  (£32.99 @ Amazon UK)
Motherboard:  Gigabyte GA-Z87-D3HP ATX LGA1150 Motherboard  (£93.55 @ Ebuyer)
Memory:  G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  (£62.12 @ Amazon UK)
Video Card:  Asus GeForce GTX 760 2GB Video Card  (£192.00 @ Aria PC)
Total: £554.60
(Generated by PCPartPicker 2013-12-28 21:51 GMT+0000)
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268616
Total: £554.60
aswome i'll look at them more in depth. thanks
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268643
psu: corsair cx 600
Asus and Corsair (as others have said) demand a high price premium, Maybe get other brands and get a better GPU or something.  Other than that best of luck with your new build!!!
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268793
i dont know what it is with me but i always stick to one brand and thanks for the luck :)
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268847
im using a zalman z11 plus atx case
Do you have it already or are you planning to buy it?
What's your budget then?
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268887
im planning on buying it and my budget is around £500
One more thing--what's the system being used for?
https://linustechtips.com/topic/94628-my-first-pc-build/#findComment-1268924
