First build, am wondering if I buy a 600-800 watt power supply is the components motherboard,CPU,graphics, are they all are set to a certain power setting, just wanted to have no problems upgrading later if I need more power for graphics or a new preccessor...thanks for any input...just learning builds and specs...thx
https://linustechtips.com/topic/945898-power-supply/
Just need to make sure your PSU has wattage to cover the combined total of all your parts. Use pcpartpicker to map out your build and it will give you an estimated wattage.
Also, check what cables your PSU comes with (6 pins) and make sure it will work with whatever graphics card you're going to get (some high end cards need two 6-pins).
Also, stick to recognisable brands and have a look at the PSU Tier List in my signature.
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
https://linustechtips.com/topic/945898-power-supply/#findComment-11517223
Just dont check only power for a psu , the psu is the most important part of your build , it gives stability to all your system , its the stability of that power that makes a psu more expensive and reliable , as Ezzy-525 says there's an excelent topic about tier psu's on this forum
I've had 2 rx 480 mining + i5 2500k + monitor (on a 800w psu) drawing 350w from the wall, any 500-600w could run almost any single gpu build but there are from 30$ to 150$ same power so dont cheap on this important piece :D
Tier 2-3 from that list are the way to go quality/price
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/945898-power-supply/#findComment-11517264
im building a pc for £100, do you think this case power supply combo lookes to dogey? have you got any betta combos , the power supply can be about 300w and under £30
https://www.cclonline.com/product/143872/AVP-EL03B500W/Cases/AvP-Viper-Gaming-Black-Mini-Tower-Case-with-500W-Power-Supply/CAS1124/?gclid=CjwKCAjwj4zaBRABEiwA0xwsP6D-zQJeYK8DiZOTVFTjvxGs3lidxNar_9cg72E4amRJ47eidm0IlhoCHKAQAvD_BwE
https://linustechtips.com/topic/945898-power-supply/#findComment-11517424
You should make your own post...
Don't buy that though.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/945898-power-supply/#findComment-11518043
You don't!
Because if you ask this way, you won't need it anyway.
What you want is a good quality unit first.
Watt comes later as most modern components can run off a 400W PSU without any problems.
So 600-800W is just a waste, especially if we talk about the 80plus Bronze crap as there aren't many good ones in that Watt Range.
Get a good quality 80plus Gold one like be quiet Straight Power 11, Bitfenix Formula and so on.
You won't even have Problems with a lower Wattage for various reasons.
So no need to go ballistic on the Wattage.
A lower wattage but higher quality is what you want/need anyway.
As for Components:
An i7-3930K with an RX480 OC (Power Color Red Devil) can run off a 400W without Problems.
A Ryzen 7/1700x with _TWO_ 7970GHz/280X can run off a 550W PSU.
So why go for 600-800W???
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/945898-power-supply/#findComment-11519004
If you want to burn down your house you might choose that...
But that's the Problem. Most of those are of so bad quality that its not worth thinkin about them...
https://linustechtips.com/topic/945898-power-supply/#findComment-11519008
