I was wondering if someone could look at my PC Specs I'm saving up for as I want to know if everything is going to fit in the case.
╠► CPU : Intel Core i7-8700k (3.7Ghz) LGA1151 £255
╠► Mother Board : ASUS H110M-K £59.95
╠► RAM : Corsair Value Select Memory 16GB 2133 MHZ Dual Channel £120.49
╠► GPU : NVIDIA GeForce GTX 1080 8GB GDDR5X £440
╠► PSU : Thermaltake Smart SE Modular 530W 80+ Certified £52.81
╠► HDD : Seagate Baracuda 1 TB £36.32
╠► SSD : Samsung SSD 120 GB £29.97
╠► WINDOWS 10 x64 Anniversary Edition £19.99
╠► Casing : Thermaltalke C22 Black Edition £59.99
╠► CaseFans : £13.47
╠► 1 Thermaltake Ring 12 140mm £21.95
TOTAL - £1,109.94
Hopefully everything will fit and hopefully someone could reply saying whether everything will fit or not.
https://linustechtips.com/topic/945723-would-my-specs-work/
-Moved to New Builds and Planning-
That should all work. I would get a Corsair CX550M instead of the Thermaltake PSU that you have listed there, though.
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515670
Motherboard is not compatible, motherboard is a bad match for the CPU, get a better PSU.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515683
Use Pcpartpicker.com to have an easier time finding compatible parts.
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515688
1 minute ago, LeoNeedsHelp said:
Yep.
EDIT: as @LienusLateTips said, your motherboard and CPU are incompatible. I missed that in your original post, you'll want a Z370 board.
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515699
Everything is not fine.  That MB will not work with the CPU you have chosen.
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515701
@Crunchy Dragon Is this the right Motherboard? There are a whole load of options to pick from and I don't know which one would be better for my system. It's an MSI Z370 GAMING PLUS LGA 1151 (300 Series) Intel Z370 SATA 6Gb/s USB 3.1 ATX Intel Motherboard
https://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16813144113&ignorebbr=1&nm_mc=KNC-GoogleUKAdwords-Global-PC&cm_mmc=KNC-GoogleUKAdwords-Global-PC-_-pla-_-Motherboards+-+Intel-_-N82E16813144113&gclid=CjwKCAjw7IbaBRBqEiwA6AyZgtabrbQM8NYjlxpaQs8IUFPYkzm36H5qUYxjUyPZZCk4nkD074o6RBoCy5AQAvD_BwE
EDIT: Do I need to change my CPU at all?
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515706
-snip-
That's a good motherboard.
Try using uk.pcpartpicker.com, it comes with ratings, and will check for you to see if your parts are compatible. It also checks for the cheapest price across all the major UK stores.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515710
Thanks for the feedback! I'll keep that in mind next time I look for PC parts. :)
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515715
1 minute ago, KarathKasun said:
Ive not used any boards for the Z370 platform but that would likely be fine.
Here is a Gigabyte model that is a bit cheaper.
https://www.newegg.com/Product/Product.aspx?Item=N82E16813145048
That appears to be a 4+2.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515716
@Crunchy Dragon Will the new Motherboard (MSI Z370 GAMING PLUS LGA 1151 (300 Series) Intel Z370 SATA 6Gb/s USB 3.1 ATX Intel Motherboard) be able to fit the Intel Core i7-8700k (3.7Ghz) LGA1151 onto it?
Also thanks for all of the support you have given guys!
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515730
Which will be fine.  I don t think the user is going to be aiming for a 5ghz+ OC.
With a decent air cooler they will likely be able to run with "all core turbo" or other similar setting turned on.
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515731
Yes. Z370, H370, B360, and H310 would all work, though only Z370 boards allow for OCing.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515756
Yes, that's fine.
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11515791
look for an SLI plus instead, better VRMs.
https://linustechtips.com/topic/945723-would-my-specs-work/#findComment-11516203
