As long as they're not super super cheap, they're all mostly the same. Unless you're needing shielded cables, you don't need to worry too much
Gold plated is marketing nonsense, the internal wire that actually conducts the signal is still copper.
EDIT: CAT rating does matter though. CAT5 and CAT6 will support different speeds.
it either works or it doesn't, gold plated is gimmick
if you really need cat6, you should have cat6 compatible devices that can use the 10Gb, so if it's a scam it would only do 1Gb, while if it is real cat6 it will do 10Gbit (short distance)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Thanks for the information guys. And only reason I'm considering cat 6 is due to my isp adding 1gb download soon, so wanted to prepare a little. I bought a Netgear C6300 Modem to upgrade from the POS we've been renting.
So if were not getting 10GB download, cat6 is pointless? Just wanted something the most stable connection.
yes, since cat5/5e can do gigabit, while cat6 can do gigabit AND 10 gigabit via short distance.
You're at the speed limit of 5/5e, but not fast enough to require 10. If nothing in your house can do cat6, no point in cat6.
Assuming you mean gigabit network package and it gigabyte. 1GB = 8Gb.
Yes and no. Cat5e can do Gigabit, but there's no harm in going for a higher Cat cable so you can support 10Gb in the future, especially if you plan on wiring up the house with it.
Very interesting, does the MHz make any noticable difference? I notice they vary from 250-1000 MHz.
It makes a difference in terms of bandwidth supported. Cat6 at 1Gbps and Cat5e at 1Gbps will be exactly the same.
1 hour ago, xtr650 said:
I take it as the higher the MHz the better?
Technically, yes. Higher MHz generally means it supports a higher bandwidth.
Though going for a cable with a higher MHz won't make a difference to performance, provided both cables support the same or higher bandwidth than the rest of your network infrastructure (in this case, 1Gbps)
5 hours ago, xtr650 said:
Probably a really stupid question but couldn't hurt to ask. Can anyone recommend a good brand cat 6 cable or do they all pretty much preform the same. Is 'gold plated' worth it or just a marketing gimmick.
Thanks lads.
To my understanding they come in two types Copper and CCA. CCA is an aluminum wire with copper coating. You dont want that. You want full out copper, for best results.
