How to remove old/hard/stubborn thermal paste delicately?
Solved by m0k,
i used the arcticlean product from amazon and it worked perfectly.
the first bottle is the Thermal Material Remover and it does exactly what it says, it emulsified the hard thermal paste into liquid. all i had to do then was soak up the liquid with a paper tower, didnt even have to wipe or scrub it off.
Featured Topics
Hey_AND1 ·
Posted in Peripherals1 -
INotPablo ·
Posted in New Builds and Planning1 -
4
EdoTensei ·
Posted in Graphics Cards2 -
Idkwhattodowithmylife ·
