22 minutes ago, 1NIGHTMAREGAMER said:
Also what u mean something from 90s
90s as in 1990s. To be safe, something from the year 1998(the year Windows 98 was released) would work.
Halo CE is a bit much for a Voodoo 3, especially if it's a V3 1000 or 2000. Those cards run well with games from 98-2001 and after that it's over. Halo CE on PC is a 2003 game.
Also, the default voodoo drivers are for Glide only, not for D3D. You need D3D drivers for that. Look for the DirectX drivers in the link below.
https://3dfxarchive.com/voodoo3.htm
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Hell man.. lets get the lighters out for 3DFX.
I owned one, couldn't tell you how to get it working today though. I was an abused child being forced to use DOS and Windows 3.1 so I blotted out all those old painful memories.
"Only proprietary software vendors want proprietary software." - Dexter's Law
