What resolution are you going to be gaming at?
Target framerate, settings as well?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/944095-first-pc/#findComment-11501027
Added dual channel RAM for better performance out of Ryzen along with faster clocked memory for more performance improvements. Dropped the Hyper 212 as the stock cooler is just as good. Bumped the SSD to 240GB for a few bucks more. Swapped out the PSU for something of much better quality. If you plan on overclocking and want to shave a bit off you could swap the 2600X for a 2600.
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($209.89 @ OutletPC)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  ($129.99 @ Newegg Business)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-2800 Memory  ($79.99 @ Newegg)
Storage: Inland - 240GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.39 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card  ($229.99 @ Amazon)
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($41.88 @ OutletPC)
Total: $805.11
Generated by PCPartPicker 2018-07-03 17:27 EDT-0400
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/944095-first-pc/#findComment-11501044
PCPartPicker part list: https://pcpartpicker.com/list/cFW4NQ
Price breakdown by merchant: https://pcpartpicker.com/list/cFW4NQ/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($159.99 @ Amazon)
Motherboard: ASRock - X370 Pro4 ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3000 Memory  ($89.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Video Card: PowerColor - Radeon RX 580 8GB Red Devil Golden Sample Video Card  ($269.99 @ Newegg)
Power Supply: Corsair - CX (2017) 650W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Newegg)
Total: $763.22
Generated by PCPartPicker 2018-07-03 17:29 EDT-0400
More value for money.
Swapped PSU, MOBO, RAM, GOU and CPU. It will be a an nice upgrade platfrom, though you sacrifice some looks
https://linustechtips.com/topic/944095-first-pc/#findComment-11501047
3 minutes ago, Donkeyface867 said:
What about wifi?
Do you have the ability to use a Powerline adapter instead? It will allways be better than wireless. Unless it doesnt work.
Either that or get a wireless card from Asus or TP-link. Avoid the cheapest ones as they are reported to be iffy on connection.
And will the stock cooler be enough for overclocking?
It will be enough for a basic overclock. No need for aftermarket cooling
Il create a build woth Wifi, just give me a min
https://linustechtips.com/topic/944095-first-pc/#findComment-11501084
PCPartPicker part list: https://pcpartpicker.com/list/s2Fs8Y
Price breakdown by merchant: https://pcpartpicker.com/list/s2Fs8Y/by_merchant/
Wireless Network Adapter: TP-Link - TL-WDN4800 PCI-Express x1 802.11a/b/g/n Wi-Fi Adapter  ($35.85 @ Amazon)
Total: $789.07
Generated by PCPartPicker 2018-07-03 17:46 EDT-0400
Includes wifi
https://linustechtips.com/topic/944095-first-pc/#findComment-11501093
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.99 @ Amazon)
Motherboard: MSI - H310M PRO-VD Micro ATX LGA1151 Motherboard  ($54.99 @ Amazon)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-2400 Memory  ($139.99 @ Newegg)
Storage: Inland - Professional 120GB 2.5" Solid State Drive  ($24.99 @ Amazon)
Storage: Seagate - Barracuda ES 750GB 3.5" 7200RPM Internal Hard Drive  ($23.99 @ Amazon)
Video Card: MSI - GeForce GTX 1060 6GB 6GB GT OCV1 Video Card  ($275.99 @ Newegg)
Power Supply: Corsair - Builder 500W 80+ Bronze Certified ATX Power Supply  ($24.99 @ Newegg)
Total: $748.92
Generated by PCPartPicker 2018-07-04 14:42 EDT-0400
https://linustechtips.com/topic/944095-first-pc/#findComment-11503944
On 2018-07-04 at 11:51 AM, forregacc02 said:
This is the old CX... oh my...
7 minutes ago, Donkeyface867 said:
I will be overclocking r5 2600x to 4.2ghz, will that be enough?
4.2Ghz gets it faster than it's competition in most games.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/944095-first-pc/#findComment-11513648
11 minutes ago, Donkeyface867 said:
i will do two sticks of 4gb of ram, i have i terabyte internal hdd and a external hdd with 4 terabytes, so i dont really care how much the ssd has. should i do 400 or 500 watts
Wattage on the sticker doesnt matter as much as who makes it. All power supplies arent created equally. A good quality 500W should be enough for that system.
https://linustechtips.com/topic/944095-first-pc/#findComment-11515296
53 minutes ago, Donkeyface867 said:
what are some good cases for my build under 100
50 minutes ago, Donkeyface867 said:
thanks
49 minutes ago, Donkeyface867 said:
also is there any good mobos under 100
Have you read our build suggestions?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/944095-first-pc/#findComment-11515474
