Code Error C0, no post and no signal to mouse or key board
Hey guys I built a brand new system and i keep getting Error Code C0 on my Msi x370 titamium with ryzen 7 2700x. I need help i tried different motherbords and i brought another 2700x  to check and i keep getting error code C0. Please help if u can
look at your motherboard Manuel and find out what that specific code means
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
Have you tried reseating the CPU?
  • CPU:  AMD Ryzen 7 7800X3D
  • Motherboard:  MSI PRO B650M-A WiFi
  • RAM:  G.Skill Trident Z5 RGB 32GB (2 x 16GB) DDR5 Memory @ 6000MHz
  • Graphics:  Colorful iGame GeForce RTX 3070 Ti Ultra W OC 8G-V
  • StorageKingston KC3000 2TB M.2 PCIe NVMe Gen4 SSD; Seagate Barracuda 2TB Hard Disk Drive @ 7200rpm
  • PSU:  Cooler Master V1000 1000W 80+ Gold
  • Case: Corsair 4000D Airflow
  • Keyboard: Cooler Master CK550 RGB Mechanical Gaming Keyboard w/Gateron Red switches
  • Mouse: Glorious Model O- Wireless @ 1600dpi, 1000Hz
  • DAC: JDS Labs OL DAC
  • AMP: JDS Labs O2 AMP
  • Headphones: Hifiman HE-400I w/ZMF Ori Lambskin pads
  • Soundbar: Creative Sound BlasterX Katana
  • Monitor 1: BenQ EL2870U @ 3840 x 2160, 60Hz
  • Monitor 2ASUS Predator XB252Q @ 1920 x 1080, 240Hz
  • Monitor 3AOC G2460 PQU @ 1080 x 1920, 144Hz
yes i even brought same new cpu and motherboard
I looked and it doesn't show what C0 code is
From the research I did online, it could be an issue with RAM configuration and DIMM slots, try booting with only one stick of RAM and see what happens.
  • 2 weeks later...
I found out the problem all 3 motherboards i use did support AM4 but not the 2nd gen ryzen cpus
