I a looking at buying a 1060 6GB and the one I want to get is £300 including shipping, I want to get this one as later down the line I can water cool it (Gigabyte G1 gaming 1060 6GB card) but there is another card for £50 cheaper and with a free gaming mouse but I can not water cool it later down the line (Asus Dual 1060 6GB gaming).
G1 1060: https://www.ebuyer.com/780573-gigabyte-gtx-1060-6gb-g1-gaming-graphics-card-gv-n1060g1-gaming-6gd-v2
Dual 1060: https://www.ebuyer.com/753392-asus-gtx-1060-6gb-dual-oc-graphics-card-dual-gtx1060-o6g
The reason I want 1060 6GB is because I am on a budget and therefore am not looking to be upgrading too soon.
The water cooling gear I want to be using is only EKWB and I want to water cool my card so can not be 1050 if anyone knows of any 1060 6GB cards around the same budget as the dual and can be water cooled please let me know and also the payment has to be in the Steerling Pound.
https://linustechtips.com/topic/943711-water-or-value/
Dont watercool a 1060, it'll cost just as much as the 1060 itself and offer little performance boost. Same as what you can do with a air cooled 1060
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/943711-water-or-value/#findComment-11497790
if you have the money for watercooling, spend all of that on the graphics card and stay on air. Imo among currently available cards only 1080ti and Vega cards are worth watercooling.
Desktop benching:
https://linustechtips.com/topic/943711-water-or-value/#findComment-11497842
Can I ask why you plan to water cool your card? Will it be part of a loop or will it be cooled on its own? Like others have said there isn't any obvious benefit to water cooling a 1060 so if there is a specific reason you have knowing that reason will help us provide more useful opinions.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/943711-water-or-value/#findComment-11497853
I am going to be creating a water cooling loop on at least the cpu if I do add the GPU it will not be on a single loop and the main reason I want to water cool the card is that when I get water cooling the res will be acting as a GPU support and I don't think that looks the best so I want to water cool the card so it isn't sagging on the res
https://linustechtips.com/topic/943711-water-or-value/#findComment-11497899
6 hours ago, BerGar92 said:
If it's not worth water cooling a 1060 should I buy the dual 1060 now then sell it later down the line to upgrade to a 1070 or what ever series Nvidia calls their line up (1170)?
It's not worth watercooling the 1070 either. The only things worth overclocking are 1080tis with bad coolers and Titans. Just get a 1080/ti with the watercooling money and you'll be much happier.
For pure aesthetics watercooling is awesome though, so it depends on what you're looking to get out of your PC
That's an F in the profile pic
https://linustechtips.com/topic/943711-water-or-value/#findComment-11498849
The Asus 1060 Dual has a strong shroud that helps holding the card straight. I dont need a support beam for mine at all.
Dont upgrade to 1070. Your next step should be the 1170 or 1260 (a next gen card of a higher tier, or next 2 gen card of the same product tier)
Desktop benching:
https://linustechtips.com/topic/943711-water-or-value/#findComment-11498887
