i5 8600k Overclock speed, voltage and temperature
11 hours ago, ElderNoob said:So i just finished an hour of prime95 test just now (Blend Test), it didn't crash nor stopped, HWinfo64 never showed any kind of throttling.
However, a couple of cores showed max temp of 92 at some point, but most of the time its between 75-85 deg. Is this healthy?
92 is usually a bit high, though I think that since prime95 is so unrealistically hard on your CPU that in day to day usage it should be fine.
11 hours ago, ElderNoob said:Also i noticed the TDP from XTU running on the background, I saw it showed briefly some 115W TDP, i remember the TDP of i5 8600k is just 95W..is it ok? it never registered any throttling due to this though. and mostly it sits at 80W TDP..
The 95w is only at stock. When you OC it's gonna increase the TDP by a lot... I reckon the 115W also isn't 100% accurate as your CPU is probably pulling a lot more than that.
11 hours ago, ElderNoob said:and lastly, my OC is 5ghz, how come when i run prime95, CPU-z and XTU only showed 4.7ghz @ 100% utilization? does it mean it only tested 4.7ghz instead of 5ghz?
If that's the case it's probably only running at 4.7. Look in your bios to see if there are any AVX offset settings... That might be the reason.
AVX workloads stress the CPU a lot more than normal, and Prime95 includes AVX workloads. You should be able to set an AVX offset in your bios so that, say, if you're running at 5 ghz when under AVX your CPU will go down to 4.8.
