Deciding on Building a server Need help!!
Solved by NelizMastr,
6 minutes ago, TrueCanadian said:I would like it to be able to be a NAS and make some of it and gaming server. Like where i run a dedicated server.
See, you're not elaborating at all. You keep using the word "gaming server". What's that supposed to do? Run and play actual games? Or just the basic dedicated servers you connect to from your actual gaming PC?
I'm kinda with @whoisit1118 here. It doesn't sound like you'll actually need a full blown server for this. You're overcomplicating things in a field you're not familiar with, which isn't great.
