Need help picking Noctua cooler
Sack
Hi, I've been thinking of swapping out my 5 year old Corsair H100i with a Noctua cooler ever since I took the plunge and replaced all of my case fans with Noctua ones. My problem is that I don't know for sure how I will know what will fit, and what won't, mainly been looking at the NH-D15 model since I have ram with a low heat spreader on. Anyone know if it will fit? Or possibly how I can find out if it will fit (what/where to measure)?
CPU: Intel i7-4770k (not overclocked)
RAM: Kingston Hyper X beast x4
Case: Corsair 750D
It will fit. As for your ram since you say it’s low profile I’m 95% sure it will fit but if it doesn’t you can just move the fan up a bit
poop
I have a 760t corsair and a high profile ram with that noctua, dont worry it will fit for sure , the main issue is that you need to lift a little bit (if so) the right fan , to make a little space for the ram.
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
That’s what I said lmao
poop
Or move fan to other side.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Would that have any bad effects? Cuz I just see people moving up the fans. And about moving up the fans, will THAT have any bad effects? (Not really an air cooler dude I like my aesthetics but just in case I get one in the future)
poop
Moving fan to other side doesn't. You might need to consider if you need rear exhaust or not. Moving it upwards is maybe. If you would need to move it so much that 1/3 of fans area is above cooler, you will loose some of its performance. How much that is in temps, I don't know. And I don't think anyone has tested it. Usually you need to move so little it stays within margin of error.
It will fit just fine.
Suggestion, try to buy used because even if someone used it, they are usually not battered and looks no different from new
Moving the fans away from center or a fan to the back of the heatsink is generally slightly worse but it's not a huge difference.
Are you sure you have HyperX Beast ram? That's pretty tall at 46.5mm compared to the standard profile for ram at ~30mm. In either case, it should still fit with the adjusted fans. The NH-D15 has a cut out for ram up to 64mm.
Are you planning to oc? The NH-D15 is massive overkill if you're just using stock settings.
On 6/27/2018 at 10:17 AM, Sack said:
NH-D15
NH-D15S ships with one fan and the fin stacks are off-set for RAM and pci-e clearance.
Runs within 3C of the NH-D15 with two fans.
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
